Group: DynoMotion Message: 8193 From: eric_kato_sanders Date: 8/28/2013
Subject: Bug in KMotionCNC tool path Viewer
I've been working on my own version of KMotionCNC. While adding separate colors for arc commands, I discovered this problem.
It looks like the part coordinates are fed into the G Viewer, however if you are using tool length compensation, then the part moves are offset in the Z axis by the tool length. The result is what you see aren't tool tip paths any more. The tool length needs to be added to the Z coordinates fed into the GViewer.
Eric
Group: DynoMotion Message: 8195 From: eric_kato_sanders Date: 8/28/2013
Subject: Re: Bug in KMotionCNC tool path Viewer
--- In DynoMotion@yahoogroups.com, "eric_kato_sanders" <eric@...> wrote:
> Hi Tom,
> Eric
It looks like adding this to the three viewer callback functions fixes it:
z += TheFrame->GCodeDlg.Interpreter->p_setup->tool_length_offset;
Let me know if I'm using the correct variable for the offset.
Group: DynoMotion Message: 8196 From: ericncn Date: 8/28/2013
I confirm I've noticed that too, but I believed it was wanted
EC
> Hi Tom,
> Eric
Group: DynoMotion Message: 8209 From: eric_kato_sanders Date: 8/29/2013
I typed this in wrong, it should be
z -= TheFrame->GCodeDlg.Interpreter->p_setup->tool_length_offset;
For the benefit of those not using tool offset tables, let me explain how they work. Tool-1 will be your probe. You touch off of the table surface and set your Z to zero. Next, you insert your tools one by one and touch off the surface. The Z reading you get on contact is your tool offset entered into the table.
For a tool change to tool-2, your G code would have something like:
T2 G43 H2 (change to tool-2 and apply the tool offset for tool 2)
KMotionCNC will subtract your tool offset from the current Z reading. Say your tool-2 offset is -1.000, (in other words, your probe would have been 1" longer than tool-2). When the tool change occurs, the offset will be applied and the Z dro will now read 1.000. The spindle will need to drop 1" for the tool to make contact with the datum surface.
> --- In DynoMotion@yahoogroups.com, "eric_kato_sanders" <eric@> wrote:
> > Hi Tom,
> > Eric
Group: DynoMotion Message: 8213 From: Tom Kerekes Date: 8/29/2013
Hi Eric,
Thanks for that.  Currently the plot shows the raw machine motion in all cases.  It doesn't compensate for Fixture offsets, Origin offsets, Tool Length Offsets, or Tool Radius Compensation.  But I can see the advantage in this case.  I suppose it should be an option?
I think if you are going to compensate the plotted path then the current animated tool position should be offset to match.  The Interpreter look ahead might make that a bit tricky.
